Is 58mm Throttle Body Worth It
Old Apr 6, 2007 | 09:02 PM
crazycat's Avatar
Default Is 58mm Throttle Body Worth It
Hi I have a 95 camaro that I will be getting dyno next month. My mods are
Advanced injection Ported heads,mild cam, super comp headers.STS turbo system,42lbs injectors,msd ignition. The car dyno 360rwh before turbo install. Anyway I was thinking of getting a 58mm throttle body, is it worth $350 ? Will It make much differance? thanks
Old Apr 6, 2007 | 09:14 PM
LT1Falcon's Avatar
ive heard you get nothing with it on a stock motor, but it helps a little with a built engine (sounds like your case)
Old Apr 6, 2007 | 10:29 PM
crazycat's Avatar
If its only going to give me 5 or 10hp then I wont get one. Has anyone noticed a big differance with theres ?
Old Apr 7, 2007 | 02:26 AM
siniSSter's Avatar
Since you have boost, I'd get one.
Old Apr 7, 2007 | 04:48 AM
3pnt4maro's Avatar
i would say no unless your running some boost which you are...so then i would say you might see some benfit..not saying how much but it couldnt hurt
Old Apr 11, 2007 | 11:30 PM
RedsTA's Avatar
On our local board a couple guys did a dyno testing with all sizes of tb's and they noticed like a 10rwhp 15rwtq gain with the 58mm tb.
Old Apr 12, 2007 | 02:58 AM
Formula350's Avatar
I noticed a diff on my TPI motor. I have yet to install it on my 93, regardless of what my sig says lol. I did port my TPI plenum to beat hell though, so it had no restriction mating up to the 58 like a stock intake would.
