egr block off plates
Old Apr 7, 2007 | 07:47 PM
redhot lt-1's Avatar
Default egr block off plates
i`m thinking fo getting a set and was wanting to know if any body has had any problems with it and if anybody has had any advantages with it. please post and let me hear your opinion it is welcomed
Old Apr 7, 2007 | 08:02 PM
FlamingChicken's Avatar
I got mine from sjm and they were pretty nice. The only true advantage would be to clean up your engine bay and keeps carbon from being dumped back into your intake.
Old Apr 7, 2007 | 08:09 PM
i`m wondering if it will do any thing to my drivablity also
Old Apr 7, 2007 | 11:11 PM
emerica4601's Avatar
From: king of prussia, pa (home) and williamsport, pa (school)
these are only necessary if your doing longtubes w/out emission fittings. you dont need to waste yoru money on the expensive ones online. get yoruself a peice of sheet metal and some metal sheers. take off the existing egr plates, trace around them on the sheet metal, and cujt them out. drill holes accordingly.
have fun
Old Apr 7, 2007 | 11:21 PM
ckyconan2003's Avatar
use the gaskets instead of the egr valve itself if you plan to make your own. Much easire to trace. I bought mine from UMI, but dont delete EGR if you arnt getting non-emission LT's
nice pic on your post!! but my problems that i have emission legal lt`s but there leaking at the egr tube connection and i found premade kit for $30.00 at herron
performace.com
Old Apr 8, 2007 | 12:14 AM
BLACKSHARK's Avatar
I fabricated my own had no problems with it.It cleaned my bay up greatly and its easier to work on my car(after all egr is gone.)
Old Apr 8, 2007 | 10:16 AM
ws6chicken's Avatar
I ebayed my block off plates for like 15.00 shipped. But if you have access to some scrap sheet metal (aluminum) go for DIY block off plates they're very straight forward to fabricate.
 Michael S. Palmer
Old Apr 8, 2007 | 11:47 AM
Matts94Z28's Avatar
I got mine from shon herron also. The quality is awsome.
Old Apr 8, 2007 | 11:38 PM
96mikez28's Avatar
Did you guys end up taking off the intake manifold to get to the EGR valve?
Old Apr 9, 2007 | 09:29 AM
Shon Herron's Avatar
Nope, just a 10mm or 13mm wrench will get the nuts off the studs.
Old Apr 9, 2007 | 11:56 AM
Ls1Bait's Avatar
^^^Yea you dont have to remove the intake to do them.
Old Apr 9, 2007 | 12:00 PM
1QWKT/A's Avatar
I forget which it was, AIR or EGR, but I took the factory plate that had a steel line running through it, dremeled the steel line and then plugged the resulting hole with a quarter and JB Weld. Cost me 25 cents and it's holding up damn good compared to the pricey block-off plates.
