testing for leaking injectors
Old Apr 10, 2007 | 06:58 PM
ty97z's Avatar
Default testing for leaking injectors
i bought NEW 37lb racetronix inj and having a promblem with the car flooding in the first 5 seconds of running how can i check if one or some are leaking? is there anybody that test them?
Old Apr 10, 2007 | 07:25 PM
slamm69's Avatar
I need to know too.I am having a problem that I think is a leaking injector.I put a fuel pressure gauge on it and in about twenty minutes it had dropped from 36lbs down to 20lbs with the engine off.But I dont know whats normal.
Old Apr 10, 2007 | 08:30 PM
Low N Slow's Avatar
Any shop can test them for you, or you can do it yourself if you have a fuel pressure gauge and an injector pulse tester. I picked up a pulser for $40
Old Apr 10, 2007 | 08:49 PM
Speed Density's Avatar
hashtagBMW
I want to say that either Racetronix, Thunder Racing or Harris Speedworks can test them. Not sure which one though.
You just send them off and they test them and send them back with the flow results. I think they clean them too.
Tony.
Old Apr 10, 2007 | 09:03 PM
borninatransam's Avatar
i just put a set of 37 lb racetronix injectors on my 383. i hope this isnt a problem with a batch of injectors cause shipping back to canda isnt going to be fun
Old Apr 10, 2007 | 09:06 PM
hashtagBMW
https://ls1tech.com/forums/showthrea...=Injector+Test
Searching turned up that.
I guess i might be helping in the wrong way though. Do you think one of your injectors is clogged? Or just not functioning at all?
Tony.
Old Apr 11, 2007 | 07:33 PM
ty97z's Avatar
i dont know the motor gets flooded so quick it shuts down in 3 to 5 seconds of running!
