Car stalling
Old Apr 13, 2007 | 06:25 PM
94'BLKBRD's Avatar
Default Car stalling
I got my pcm back from pcmforless and put it in today.fired up the car and then it started to stall.Im 99% sure its not the tune.the only thing I did to the car while the pcm was out was swap out the old fuel injectors for some 36 lb SVO's.The injectors are used so do you guys think that the injectors are the problem? Sould I swap in the old injectors to see what happens??Can I run stock fuel injectors while the pcm is tuned to run 36lb SVO'S?
Can clogged injectors cause this?
Old Apr 13, 2007 | 07:21 PM
94'BLKBRD's Avatar
bump****
Old Apr 13, 2007 | 07:36 PM
koolaid_kid's Avatar
Is is driveable at all? The PCM has to go through a relearning process before it will be happy with the new settings. Just a thought.
Old Apr 13, 2007 | 07:43 PM
94'BLKBRD's Avatar
no it's not driveable,it will start but then slowly start to die
Old Apr 13, 2007 | 09:20 PM
LT1Falcon's Avatar
does it run if you give it a little gas?
Old Apr 13, 2007 | 09:51 PM
94'BLKBRD's Avatar
when you give it a little gas it still starts to die out
Old Apr 13, 2007 | 11:29 PM
94'BLKBRD's Avatar
anybody else??
Old Apr 14, 2007 | 12:05 AM
infinitebird's Avatar
Well since they were used the only thing I can think of is are you sure they are really svo 36s? If yes I guess they could be clogged, but for it to totally die it would have to be pretty bad.
Injectors are one thing you absolutely have to tune for though, so no DO NOT run your stock ones on a tune for svo 36s, if you do that it will be so lean it could cause serious damage.
greenmachine94's Avatar
just a thought but make sure everything is plugged in, if the maf or anyhting is unplugged it will do the same thing.
Old Apr 14, 2007 | 02:39 PM
94'BLKBRD's Avatar
I swap in my old fuel injectors just to check if it was the injectors ,but it does the same thing!
if the maf or anything else is unplugged wouldn't the ses light come on???
Old Apr 15, 2007 | 12:53 PM
no lights come on for me it just starts up then died real quick
Old Apr 15, 2007 | 03:59 PM
94'BLKBRD's Avatar
swap back the 36 lb svo's today and it started and ran for about 5 minutes.Is there anything I could have done wrong when I changed the injectors???
this is what I did when I changed the injectors.
1.disconnect battery
2.Open gas cap to release fuel pressure.
3.remove clips from fuel injectors.
4.remove 4 bolts from fuel rail
5.removed fuel rail just enough to get to all the injectors
6.remove old fuel injectors and put in new/used svo's
7.put fuel rail back,put clips back into place
anybody see anything wrong???
Old Apr 15, 2007 | 06:49 PM
94'BLKBRD's Avatar
bumpers
Old Apr 16, 2007 | 12:19 AM
94'BLKBRD's Avatar
should I contact bryan at pcmforless???
Old Apr 16, 2007 | 12:41 AM
siniSSter's Avatar
Did you have problems starting the car @ the beginning?
Old Apr 16, 2007 | 12:44 PM
94'BLKBRD's Avatar
no problems from the beginning,I also forgot to mention that I got the AIR & EGR removed from my PCM but I haven't removed it from my car<<<could this be causing the car to stall???
Old Apr 16, 2007 | 05:09 PM
94'BLKBRD's Avatar
bump********
Old Apr 16, 2007 | 05:30 PM
Ls1Bait's Avatar
Contact the person that did your tune cause I bet it is in there. When my pcm went out it would start for like 3-5 secs then die.
Old Apr 16, 2007 | 06:42 PM
94'BLKBRD's Avatar
well i'll contact bryan at pcmforless
Old Apr 16, 2007 | 07:59 PM
94'BLKBRD's Avatar
Got an e-mail from bryan at pcmforless and he said that my problem sounds like a VATS issue!
Has anybody else had a problem with VATS after getting your PCM tuned??
