MAP sensor problem
I read that I should check the voltage of the green signal wire to verify if it is correct at the sensor and the pcm (which would probably tell me whether it is the sensor or wiring) What's the best way to go about that? should I just strip off the plastic covering in one section?
I believe I had this code once. I took off the MAP sensor, cleaned it up, made sure the rubber seal was on proper; and last time I checked the code went away.
