car running rich
Old Apr 18, 2007 | 01:40 PM
TravisMcGill2000's Avatar
Default car running rich
i have a 94 trans am A4 it has cai,LT,4in y-pipe,pulleys,3.73.hypertech my car is running very rich or i think it is. its keeps spitting and sputtering but it does not do it all the time. There black sute all over my rear bumper. and it keeps smoking. anybody with any anwsers. please let me know i have no idea
Old Apr 19, 2007 | 09:52 AM
LOUDandPROUD96's Avatar
are you getting a system too lean code?
Old Apr 19, 2007 | 04:24 PM
i havent pulled any codes yet but my check engine light is not on. does it got anything to due with the new LT headers i put on
Old Apr 19, 2007 | 04:41 PM
WhyHelloOfficer's Avatar
When was the last time the car had a tune up? What is the condition of the plugs, wires, and O2 sensors?
Did it just recently start doing this? Or has it progressively gotten worse?
What type of driving triggers it?
We need a lot more info before we can even remotely give you some feedback.
Old Apr 19, 2007 | 07:12 PM
i just changed plugs and checked the plug wires they look good no cracks. i dont know about the o2 sensors. but if they were going bad wouldnt the check engine light come on
Old Apr 19, 2007 | 08:09 PM
Camz450's Avatar
They should make the check engine light come on if that bad. I had a left bank go out and it smoked like a train, at the same time i had an opti harness go bad, it would just cause the car to go dead but the bad O2 screws up the fuel air mix. Anytime you change to headers the coating can burn off inside and foul the O2 sensors, I believe that is what happened in my case, hope this helps. Also your car will probaly run rich anyway if you haven't tuned after the mods.
Old Apr 19, 2007 | 08:15 PM
av8er77's Avatar
Default Similar problem
I have a 93 TA with a similar problem. I don't have soot on my bumper but my exhaust tips are covered. If I'm not running wide open it spits and sputters a bit. When I bought the car I was told that the chip had a "nitrous tune" so I figured that was why it was running a little rich. Is that possible? I'm brand new to computer tuned hot rods so I just took his word for it.
Old Apr 19, 2007 | 08:16 PM
hey man thinks alot. how much will a tune help my car after i get the O2 sensors changed.
Old Apr 19, 2007 | 08:43 PM
Camz450's Avatar
A good tune can make 15 to 25 hp difference depending on application. The car will still perform without the tune so it is not exactly ness. just to drive, your idle should not be stumbling though and drivability should be the same, LT1 run alittle rich anyway, and when LT's are added and ex. backpressure lessoned they seem to get richer.
