supercharger question
Old Apr 18, 2007 | 04:18 PM
95_transam_lt1's Avatar
Default supercharger question
i was thinking about putting a sc on my transam. i know i need injectors fuel pump, and adj regulator. the car has an offroad ypipe and catback. if i run like 4.5 to 7 psi will i blow anything up?
Old Apr 18, 2007 | 05:14 PM
krayzie7th's Avatar
I would think 7psi would probably be the max that you could safely run.
Old Apr 18, 2007 | 05:30 PM
TravisMcGill2000's Avatar
i have heard 10psi on a stock bottom end. but krayzie said about 7psi safely
Old Apr 18, 2007 | 06:35 PM
Jon@BruteSpeed's Avatar
LS1TECH Sponsor
I am currently at 9 psi on a stock engine. It is primarily raced and I keep good gas in her. She has been damn consistant!! Hope to shed a few pounds and get her in the 10's on stock motor(with exception of valve springs and rocker arms). I put 500 street miles on it before I went with T400 and 4.30 gear.
Keep it at 8 or below with after coolers and with a good tune you will be alright.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
Old Apr 19, 2007 | 03:57 PM
do you use it on the street?
