solid motor monuts?
Old Apr 19, 2007 | 05:06 PM
mean94lt1's Avatar
Default solid motor monuts?
i got a set of madman solid motor mounts for my 94 z i am also doing long tubes at the same time has anyone used these solid motor mounts? they came today with no directions i know its just a motor mount but anyone with some info please help!!!
Old Apr 19, 2007 | 09:06 PM
Ralls's Avatar
It's pretty straight forward. Just take whatever off that's stopping you from getting to the mounts. Headers need to come off to make your life easier.. luckily your doing that anyways.
Old Apr 19, 2007 | 10:33 PM
Formula350's Avatar
It's just two pieces of steel that look like the motormounts minus rubber. Bolt them to their respected places, and then put the bolt through the mounts to hinge them together. They came with no directions because none are needed.
Old Apr 20, 2007 | 10:39 PM
Shon Herron's Avatar
Enjoy the fun!!
Old Apr 20, 2007 | 11:09 PM
IllusionalTA's Avatar
post some pic's!!!
Old Apr 21, 2007 | 12:31 AM
themadspoon's Avatar
Will they have a bolt threw the middle it seems to me like they wouldnt.
Old Apr 21, 2007 | 01:13 AM
Formula350's Avatar
Uh... what? Not sure what you're asking, or maybe even saying, but every SBC motor mount I've seen has a bolt going through the two pieces holding them together.
___
\___/
Meh, I'm drunk and pissed off, I hope that drawing makes sense Bottom is what bolts to the motor, top is the frame portions. When they come together, the bolt (which is []=====) goes through joining them.
Old Apr 21, 2007 | 11:23 AM
Ralls's Avatar
Formula350, there is no middle bolt going horizontal on the new mounts. It's a solid piece with 4 bolts going in block, and 4 bolts going in k-member. Your thinking of the other kind.
Old Apr 21, 2007 | 12:06 PM
The long bolt that goes thru the motor mounts (stock or solid) is used.
Have you decided how you are going to handle the knock sensor?
Old Apr 21, 2007 | 12:48 PM
mean94lt1's Avatar
didnt know i had to change the knock sensor?
Old Apr 21, 2007 | 01:01 PM
Ralls's Avatar
Umm no. You don't use the long bolt in the middle.
Old Apr 21, 2007 | 01:42 PM
Formula350's Avatar
OH Well then, Neva mind :S What can I say, I'm old school
Old Apr 21, 2007 | 02:46 PM
Ralls's Avatar
I think he was referring to the vibration caused by solid motor mounts. You will probably pick up some false knock from them. May I ask why your getting them? It doesn't sound like you have a highly built motor since your just getting LT's, but I have no way of knowing that.
Old Apr 22, 2007 | 09:39 PM
mean94lt1's Avatar
the top end is done heads and everything just stock bottom end for now
Old Apr 22, 2007 | 11:24 PM
the_merv's Avatar
Veteran: Air Force
Here is the kind that do take a bolt through them..
http://store.summitracing.com/partde...5&autoview=sku
That will get you some good vibration in the Car.. start puttin some ladies in it also..
Old Apr 23, 2007 | 10:32 AM
I used the Moroso solid mounts, the long bolt was used.
False knock with the KS's, I disabled mine.
Old Apr 23, 2007 | 10:36 AM
jldak318's Avatar
MADMAN'S motor mounts are a solid piece and cant be taken apart. they ONLY fit on the motor and k'member one way. take one stock one off and match it up to the madman mount and voila there ya go.
Old Apr 23, 2007 | 10:39 AM
There you go. Simple enough.
Old Apr 23, 2007 | 06:07 PM
mean94lt1's Avatar
what do i have to do in order to run the solid motor mounts so that it doesnt mess with the knock sensor or how do i get rid of it
Old Apr 24, 2007 | 05:50 AM
I turn it 'off' in the PCM. Change the table so it doesnt pull out any timing when it detects knock.
Granted this is usually done on a mostly track car.
