grinding or scraping
Old Apr 20, 2007 | 10:40 PM
Revelation Z28's Avatar
Default grinding or scraping
when im in say 2nd gear at 1200rpm (no CAGS) and accelerate, or say 5th at 1400rpm and goose it i get a grinding/vibration until i get into the powerband.
say like when you check your clutch for slipping 6th gear at 40mph and nail it to watch the tach itll make the noise.
it sounds like its coming from the bellhousing area, but i could be wrong.
i doubt bent pushrods could cause that either, since its only at low RPM with more than 1/4 throttle or low RPM more than 1/4 throttle and a higher gear.
