mph differences
Now..how long have you had the car, did you just buy it? You say something about it having 200 miles. What exactly has 200 miles on it, the car since you have had it, the Transmission..
Possibly the previous owner could have gotten a tune and they forgot to adjust the shiftpoints, or did adjust them too much, or threw in a setting inside the computer for the shiftpoints for a different gear ratio.
BTW.. there are plenty of adapters out there to go from mechanical to computer for the speedometer..
Now if you change the Tire size and the Gears, it is going to change the speed of the Vehicle, not the setting in the PCM. Bigger Tires, faster the actual vehicle speed compared to the Speedometer. Bigger the rear Gear Ratio, slower the Vehicle Speed compared the the Speedometer. You have to adjust all of this in the PCM.
What is sounds like is you have the stock programming for the 2.73's, and you have 3.73's or 4.10's in it. Don't know why it would bug out all of the sudden though..
Also, if you know so much about what things are, or are not, why haven't YOU figured it out. Stop being a jerk to everyone. Since you're new here, allow me to explain how things work: A person posts having a problem, sometimes no one knows right away, they post suggestions. More suggestions roll in, which trigger theories from other people. Eventually all the suggestions add up and someone makes a final suggestions based off of those, generally leading to the correct solution. So take a chill pill and let the suggestions roll. We're not "Car Whisperers", we don't know exactly wtf is going on with everyone's car.
