12.1 at 111 MPH today
Tomorrow I start putting the pacesetter long tubes, true duals, and maybe even the cam in.
just put the long tubes in today and the plugs where fine but the water pump was leaking all over the opti. I hope I don't have to replace it again. Hopefully it will stop popping when it dries out.
my opti got drenched when my WP went..still works great knock on wood!
I hope mine works when it dries out. I could take it for a ride Monday and **** the neighbers off. The car is a little loud now. Next is true duals or cam which requires buying tools to change springs and set spring height.
I was looking at True Duals, but I bought a nice 3-link Rear Suspension setup where the Torque Arm bolts to a Tunnel Brace with a built-in Drive Shaft Loop from UMI Perfromance, so I only have room for a Y-pipe..
It's rated for 750ft/lbs Torque though...
