Difference between optisparks in earlier and later lt1's
Old Apr 23, 2007 | 01:29 PM
blackbird94's Avatar
Default Difference between optisparks in earlier and later lt1's
is there a difference between later aND earlier moder lt1' optisparks i know one has the vent tube but is there anything else. The GM rplacement is less expensive for a optispark for a later model Lt1
Old Apr 23, 2007 | 01:34 PM
Cammed95Z28's Avatar
I'm pretty sure its just vented vs. nonvented
Old Apr 23, 2007 | 01:49 PM
LiENUS's Avatar
The later optisparks use a dowel pin cam drive while the earliers use a splined shaft drive, they're not compatible without swapping the cam, timing gear and timing cover.
Old Apr 23, 2007 | 03:59 PM
Lt1junkie's Avatar
Splined shaft drives are no good.... Fail more frequently the the dowl pin driven ones
