X-pipe for lt1
Old Apr 24, 2007 | 09:02 AM
xxxtreme36's Avatar
Default X-pipe for lt1
does anyone know which x-pipe (part #) is the best or most used for Lt's on our cars??? thanks any suggestions are awesome
Old Apr 24, 2007 | 09:46 AM
Turnin20s's Avatar
Universal X-pipe from either www.jegs.com or www.summitracing.com
I got mine from jegs but only because I made an order from them otherwise I would have gotten it from summit
Just go on either site and search in the exhaust section and you should find it in no time
Old Apr 24, 2007 | 11:42 AM
Cammed95Z28's Avatar
Does it bolt up to any long tube application?
Old Apr 24, 2007 | 11:59 AM
xxxtreme36's Avatar
so then they are all the same (pending size) and they are weld on correct?? weld on muffler and then at the LT's?? any suggestions as to what bullet type muffler sounds the best?
Old Apr 24, 2007 | 12:57 PM
Rowdy94's Avatar
You will get a ton of opinions on that question. Listen to any that you can find and try to make a decision. With most of them, you can't really go wrong for an LT1.
Old Apr 24, 2007 | 02:16 PM
LT1MAN's Avatar
go to summit's website. search for universal x pipe kit 3" (if thats the size you want). it will come in pieces. the actual "x" will be assembled but the rest needs to be welded. it comes with clamps but clamps are ghetto. they do not come with the flanges to meet your headers. muffler shops will have those, or summit probably has them too.
Old Apr 25, 2007 | 01:01 AM
94'BLKBRD's Avatar
here's a website that can help you
http://www.lt1engine.com/techaids/trueduals.html
