1.6 RR's on bolt on car
Well If it requires changing springs might as well swap the bump stick.
True, but that requires buying the cam, all the necessary gaskets for the swap, a timing set, possibly lifters & pushrods and not to mention tunning after its all said and done.
and can you use a spring thats good for like 550 lift with the stock cam and 1.6rr?
i should know this...ive done the came stuff before...i just went big the first time...thinking about bolting some on my dailly
"The heavy hitter in the group is a set of 1.6-ratio extruded-aluminum roller rockers from Comp Cams. By raising the LT1's valve lift from .447-inch/.459-inch to a more aggressive .477-inch/.490-inch, the rockers boosted rear-wheel output by an impressive 11.4 hp and 10.2 lb-ft of torque. Self-aligning and built on a narrow-body design, these units clear the LT1's center-bolt valve covers and can be installed with no additional modifications. SLP does, however, recommend upgrading the valvesprings on any 100,000-plus-mile LT1 engine."
Of the mods they did this was the best gainer.
Also GM High Tech Performance listed the top 10 mods for the LT1 (bang for the buck) here is what they said:
A higher ratio, roller tip and roller bearing, narrow body, self-aligning rocker arm that beats the stock part in every aspect. The high ratio (stock is 1.5) facilitates increased engine induction by increasing valve lift. Fancy roller-bearing design helps cut parasitic losses from valvetrain. The rockers give a good boost to an otherwise lethargic stock LT1 valve lift.
The Catch:
May require some minor clearance work to factory steel valve covers.
Ease of Install:
Moderate
Wear and Tear:
Moderate
Approximate HP gain / ET reduction:
10 HP
Cost:
$366.69
Cost versus gain:
$36.67 PER HP
Hope this helps.
Just change a $200 mod to a $2,000 mod. 1.7/16 studs
2.gm guide plates
3.hard push rods
4.918 springs,titanium ret,10*locks
5.1.7 roller rockers
6.good clutch/3200-3600 stall
EDIT: Gah, I said "DO" and meant "DON'T" >_< Late edit, my bad
