93 Tach Signal Wire
Old Apr 30, 2007 | 11:03 AM
FAD2BLK93's Avatar
Default 93 Tach Signal Wire
I am about to hook up a autometer shift light and I need help with the tach signal wire. I have heard that the 93 is a different wire than the 94+...can someone please help. Which color am I after, and where is it. thank you.
Old Apr 30, 2007 | 12:36 PM
FAD2BLK93's Avatar
Bump TTT
Old Apr 30, 2007 | 01:13 PM
smoknta's Avatar
I hooked mine up to the white wire going to the guage cluster. It is also the same white wire coming off of the tach filter in the engine bay.
Old Apr 30, 2007 | 05:30 PM
FAD2BLK93's Avatar
Where is the tach filter located? thanks.
Old Apr 30, 2007 | 06:26 PM
Lt1junkie's Avatar
I believe he is telling you off the blaster coil.... Located below the driverside head. At least that is where i hooked mine into
Old Apr 30, 2007 | 09:02 PM
smoknta's Avatar
The tach filer is located right next the ignition module and coil. There is a white wire coming off of the tach filter and goes to the guage cluster for the tach. You can tap into this wire in the engine bay on the tach filter, or you can pull the guage cluster and tap into the main harness going to the cluster.
