LT1 block questions
Old Apr 30, 2007 | 11:34 AM
383astro's Avatar
Default LT1 block questions
I have a couple of questions. First, is the LT1 block basically just a one piece seal block? if not then what are the differences? Also I have a 4l60 in my 93 right? not a 4l60e? So I can use a converter for a 700r4?
Old Apr 30, 2007 | 12:18 PM
buffman's Avatar
correct one piece rear main. Yes 4l60 in a 93. 700r4 is just a less facnier name for the same transmission
Old Apr 30, 2007 | 05:39 PM
siniSSter's Avatar
It is basically just a SBC block, also remember the block has passages for our reverse cooling heads.
Old Apr 30, 2007 | 10:00 PM
383astro's Avatar
Default block
do all 1 piece blocks have reverse cooling or just the lt1?
Old Apr 30, 2007 | 10:04 PM
95hawk467's Avatar
The water pump outlets are a little different as is the timing cover for the water pump drive. The pump is driven off the cam gear
Old May 1, 2007 | 12:11 AM
LT1powered89's Avatar
Just the LT1
Old May 1, 2007 | 08:22 AM
SAPPER's Avatar
As pointed out above. The LT1's front is totally different fron a Gen I block. But there are some very slight differences in the Cranks. I have a LT1 crank and a crank from my 90 Blazer. The snouts are different. Same diameter but the LT1 is a little longer.
