383 Lt1
Old Apr 30, 2007 | 11:30 PM
borninatransam's Avatar
Default 383 Lt1
well after not being able to work on the car for a week because i was at school i went home found the problem i was having and crank my car right up. i didnt have the ground hooked that went from the battery to the body ground post so it was draining the battery and not giving the starter enough juice. cranked up first try, oil pressure jumped right up, and it sounded bad ***. im going to put the y-pipe on this weekend and load it up to go to RPM to get tuned. Ill post numbers as soon as i get them.
some specs on the motor:
2 bolt LT1 block bored 30 over
Eagle forged crank
Scat 6" h-beams
Ross pistons
TFS heads with Manley valves, flowed 270 @ .550
Comp Cam similar to 305
Comp 1.7 rockers
ported stock intake
37# Racetronix injectors
Pacesetter LT's w/ ORY
3" Dynomax bullet
3.73's with stock 10 bolt(soon to be 9 inch)
any predictions as to what kind of power I'll make would be nice. I'm guessing between 425 and 450 at the wheels and run in the mid 11sec range on MT's.
Old Apr 30, 2007 | 11:44 PM
streetwarrior96's Avatar
Eagle forged crank
Scat 6" h-beams
Ross pistons
Comp 1.7 rockers
ported stock intake
3" Dynomax bullet
Low Low 12's
380 to 400 RWHP
why did you get 1.7 rockers ans what is the CR?
Old May 1, 2007 | 12:42 AM
sorry about that. mis typed the 1.7 should have been 1.6 and the compression is 11:1. why do you think the numbers will be so low?
Old May 1, 2007 | 01:14 AM
ZONES89RS's Avatar
In-Zane Moderator
it really is a mild LT1, you need 4.10 gears too
+ suspension
Old May 1, 2007 | 10:28 AM
Dales396lt4's Avatar
The Comp Cam 305 is just to small, 220 230 and no lift.
Old May 1, 2007 | 02:48 PM
+ suspension
he has a very mild setup. I'm pushing 421 HP and 400 Tq with the 230/236 .544/.555 lift 112 lsa
Old May 2, 2007 | 06:40 AM
lt1383's Avatar
My first set up I ran comp cam 305 best time was 12.7 on street tires you should be low 12's with good set of tires.. let us know when you be hiting track. good luck.
Old May 2, 2007 | 01:30 PM
Javier97Z28's Avatar
The predictions are low b/c you're running a peanut cam in a 383.
Old May 2, 2007 | 02:30 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
the times will all depend on traction....
I ran an 11.61 @118 (1.61) w/a 222/228 .544/.538 112 in a 12:1 396 w/heads that flow 270/195
Dyno'd 422RWHP/447RWTQ through a T56 and 10bolt
Old May 4, 2007 | 09:48 PM
i made a mistake before. the cam is more like a 503. the life with 1.5 rockers was .537/.533. so if i figure correctly the lift with 1.6 rockers should be .573/.569. any better predictions with the correction in the cam? i still think i could go bigger but for now ill stick with this one, just want updated predictions.
Old May 5, 2007 | 01:11 AM
ZONES89RS's Avatar
In-Zane Moderator
1.6 rockers are said to add 2 degrees of duration too. HTH
