Fuel Trim Problem
Old May 1, 2007 | 01:47 PM
Stroker396@APF's Avatar
Default Fuel Trim Problem
I have been trying to diagnose and solve this problem for a while.
The car thinks Bank 2 is lean and is dumping fuel on it. Causing 10MPG!
I have tried to seal up any intake or exhaust leak, but the O2 still does not osolate and it is new.
here is the latest readings from the car.
Anyone have any idea what could be causing this situation?
Old May 1, 2007 | 08:30 PM
MEAN LT1's Avatar
Image shack isnt working right now but what millivolts is the passenger side o2 showing. Is it going into closed loop, I have a feeling you might have a failed o2 sensor.
Old May 1, 2007 | 08:50 PM
seems to be working now, but the reading is 0.445
This is the second O2 sensor, brand new.
Old May 1, 2007 | 09:16 PM
GMRL's Avatar
Check the injector O-rings for vacuum leaks. Same thing happen to me once, spray some water into the bungs, that makes it easy to detect leaks. Also check for leaks where the intake meets the head. Also the wiring harness for that o2 sensor.
Old May 1, 2007 | 09:23 PM
I should mention that I have been working on this for a while
So far here are the things I have done/checked
1. Injector o rings - sprayed ether to see if engine reves up - nada
2. replaced intake and gaskets - with ported for 58mm tb
3. replaced exhaust gasket and rtv sealed it to header
4. block off plates
5. RTV collector to Y pipe
6. Tighened #8 plug (it was loose) and it is the black one. #4 was gray
7. replaced O2 sensor
8. I am sure there is more I am forgetting.
9. Fixed vacuum leak from Pass firewall (to vents)
I have been told to triple check the wiring. It is not near the headers I could try swaping the bank one good O2 over but likely with the same results.
Old May 2, 2007 | 11:57 AM
flame's Avatar
Is the check engine light on? Any codes? It appears that the bank 2 sensor is flat lined at .445 indicating that the circuit is open. Likely a broken, corroded, melted wire in the harness.
Old May 2, 2007 | 12:46 PM
No Codes. I will take a look at the wiring today. I hope that is all it is and that I can find it.
