rear brake upgrade?
Old May 3, 2007 | 01:33 PM
Dr. Teeth's Avatar
Default rear brake upgrade?
So I have found scads of info on the front LS1 swap for brakes, none for any info on the rear. Any ideas what the difference is?
Old May 3, 2007 | 02:36 PM
nfa's Avatar
nfa
what are your goals for the conversion? aesthetics? performance? converting the rears is not worthwhile from a braking performance perspective. you would be better off putting the funds required to do the change into c5 or better fronts and gumball tires.
Old May 3, 2007 | 02:38 PM
seawolf06's Avatar
The LS1 rears are pretty much the same and not worth changing. Do the fronts and if you still need better braking, you're going to have to look into an aftermarket setup.
