harmonic balancer instal
Old May 4, 2007 | 06:02 PM
Ginz Ls1's Avatar
Default harmonic balancer instal
does anyone have a step by step install for this for a 93 formula cause mine broke and fell off my motor?
Old May 4, 2007 | 06:54 PM
FlamingChicken's Avatar
release tension on drive belt and remove. unbolt pulley. install is reverse. its real easy to do the damper. if you need to pull the hub then its a bit more difficult but still pretty straight forward. pull off, press on.
Old May 4, 2007 | 08:41 PM
mybluez28echoes's Avatar
Just make sure you put the three bolts as if were installing a clutch pressure plate (In that case there are 6), don't tighten one bolt all the way in, go around them and tighten them a little bit one at a time until they are all tight.
