fuel pressure
Old May 4, 2007 | 06:33 PM
Ari G's Avatar
Default fuel pressure
Iīm measuring my FP and its 37 at idle like it should be but when i remove the vacum itīs raises to 38-39 and the needle spikes/shakes,i would beleve the FP should be 41-47Psi with no vacume?Is my FPR bad?
Iīm going take the gauge and tape it to the windsheild and make a wot run,should th FP be at 43 at wot?
Old May 4, 2007 | 06:47 PM
chromeplated500's Avatar
The gm tech told me 41-42. im not sure about WOT. you should als shut off the engine and make sure it hold pressure pretty good...
Old May 4, 2007 | 07:31 PM
Ari G's Avatar
drops like a rock after i switch iff the ignition
Old May 5, 2007 | 09:12 AM
Ari G's Avatar
Took it out for a drive,itīs steady on 37 psi and when i try to make a wot it just drops to 30psi
Is it then the FPR that is the cause?i donīt see anythin else that could caus it to drop?
Old May 5, 2007 | 05:33 PM
Ari G's Avatar
anyone has been thru similar stuff?
Old May 5, 2007 | 08:47 PM
Formula350's Avatar
Clogged filter or maybe a bad FPR. Could be bad injector/s.
Old May 6, 2007 | 03:01 PM
OutlawZ's Avatar
could be bad FPR.... could be clogged fuel filter or a bad pump..... the injector wouldn't cause the rail pressure to drop so that's not the problem.... i'd say start with the filter since it's the cheapest.... after that replace the FPR..... if that doesn't fix it get ready to cut that access panel to your fuel pump underneath the rear carpet... unless you like dropping the tank......
Old May 6, 2007 | 03:21 PM
Formula350's Avatar
You've never seen what a leaky injector can do then. Prime the system, and watch the fuel pressure slowly drop to nothing.
Old May 6, 2007 | 05:51 PM
Ari G's Avatar
I aggree the injectors couldenīt drop the pressure that fast(like a stone) and the FPR is unlikely so i cut an access panel and saw that the hose from the pump the the lines was not sealing up,bought a new fuel hose and threw the TRE line in the garbage
Now itīs fine,pime it and the pressure shoorts up to 50psi and holds 41psi at idle
Thanks anyway
