whats the diff ...Lt1 block/straight 350 block
Old May 5, 2007 | 01:21 PM
95LT1963's Avatar
Default whats the diff ...Lt1 block/straight 350 block
what is the diff between a lt1 block and just a plain old jane 350 block....will the lt1 heads/intake/cam/ work with it...or what.....im just wondering....i got plenty of 4 bolt 350s laying around in my shop....
thanks
Justin Reynolds
Old May 5, 2007 | 01:24 PM
396D1SS's Avatar
no it will not work....do a search and you will find tons of info
Old May 5, 2007 | 02:10 PM
ZONES89RS's Avatar
In-Zane Moderator
I herd you can modify a LT1 topend and make it work, but it is not worth it is what i hear.
Old May 5, 2007 | 02:13 PM
Formula350's Avatar
The only reason to run the whole setup, would be A) you had it as extra B) you wanted to run the LT1 intake. I assume they'd make older school heads with Vortec bolt pattern.
Even then, I still think it needs mods.
Old May 5, 2007 | 02:15 PM
ZONES89RS's Avatar
In-Zane Moderator
What would it take to use a TPI wiring harness and use a LT1 intake?
