PS LTs Installed 1 quick question.
Old May 5, 2007 | 11:02 PM
airfix's Avatar
Question PS LTs Installed 1 quick question.
You guys with the PS LTs how did you keep the wiring away from the passenger header, 1 part of the wiring is touching the header and the other is less than an inch. Just wondering what oyu guys did to keep the wiring away from the headers.
Thanks in advance.
Old May 5, 2007 | 11:04 PM
ZFan88's Avatar
I assume you're talking about the 3rd one back...I forget which number it is. That's a bitch to get right if you don't have someone show/tell you. I ran the wire along the wire track as far as I could and then positioned the wire boot away from the header. I wish I kept my little metal blocker things that were on it stock
Old May 5, 2007 | 11:31 PM
Revelation Z28's Avatar
i ran it over cylinder #4's plug boot. cylinder #6 is the one in question.
OTVC wires going in tomorrow!!!
Old May 6, 2007 | 12:07 AM
SShawn's Avatar
i use zip ties. not the best looking way to do it, but sure as hell beats melting wires.
Old May 6, 2007 | 12:17 AM
95greenZ's Avatar
By wiring do you mean plug wires or part of the wiring harness. I extended the ks wire and pcm groundwire and rerouted them. If you meant plug wires ovc kit is the best way.
Old May 6, 2007 | 01:00 AM
TravisMcGill2000's Avatar
i cut some of the elbow off and used zip ties
Old May 6, 2007 | 01:23 AM
airfix's Avatar
Sorry I was that clear I mean the wiring harness thats between the header and the inner fender.
Thanks
Old May 6, 2007 | 01:26 AM
mines touching it, no problems. coated headers+ heat wrap (i guess GM's tin foil)
