383 question?
Old May 6, 2007 | 12:07 AM
396Z28's Avatar
Default 383 question?
well i just got my 383 stroker in my car and i was just wondering if you guys new how much rwhp i should get out of it. Here are some of my mods.
383 stroker, Eagle crank, Eagle 5.7 rods, srp flat top pistons, 58 mm throttle body 42lb injectors, 3" summit x-pipe with flow pro mufflers, comp cam 468, afr 210 race series heads 11.4-1 compression barry grant nitrous system,Moser 9 inch 3.70 richmond gear lt4 intake gasket matched
Old May 6, 2007 | 04:55 AM
Cole Train's Avatar
lol alot Not sure but i'm thinking about doing a 383 setup this winter
Old May 6, 2007 | 09:47 AM
z28hustle's Avatar
that should be reaaaaally nice enjoy it and take it to the dyno with a camera i think you should have well over 400 hp to the wheels but we shall see..
Old May 6, 2007 | 02:58 PM
OutlawZ's Avatar
at least 400 RWHP.... if not something is wrong with it..... i don't know the exact specs of that part # cam but with those heads and provided you've got all the other bolt ons like long tubes, ported intake, good ignition and coil and it's tuned properly i'd say probably like 420-430ish...... dyno it and tell me if i'm right...
