Emission AIR Delete RACE HEADERS
Old May 6, 2007 | 08:51 PM
GrnZ's Avatar
Default Emission AIR Delete RACE HEADERS
Well i just picked up some race style LT Hooker headers and what all do i need to install these? i kno i will need a tune cause it will throw codes but how do i go about the whole situation?Does the AIR pump run off a belt,if it does then i need a smaller belt? help me out i searched but am still having questions . So in total what do i need to get these on my Z thanks -ryan
Old May 6, 2007 | 09:19 PM
94Pontiac's Avatar
air pump is electric. i just did the same swap, set some time aside to do it.
Old May 7, 2007 | 08:15 AM
GrnZ's Avatar
Im kind of new to the whole thing of deleting all this stuff so is there a tutorial thread somewhere that i didnt see or could someone help me out and make a list of what i have to do. Its a 97 Z/28 with all the stock bullshit on it AIR... EGR ... how do i get my race headers on and have a less cluttered engine bay? Thanks -ryan
Old May 7, 2007 | 08:41 AM
dhdenney's Avatar
Air pump can go so just take the bracket and everything off. There is an EGR pipe on the pass side exhaust manifold that runs to the back of the intake manifold so that needs to be plugged. Air pump is on the driver side of the engine, just behind your air intake and the ABS modulator and you'll see it. You'll need something like this: http://cgi.ebay.com/ebaymotors/CHEVY...09454579QQrdZ1 for the EGR delete. It will get the pipe and the valve on the back of the manifold.
Old May 8, 2007 | 09:50 PM
GrnZ's Avatar
Where do you plug the AIR from the engine ?? pics? tutorial?
Old May 8, 2007 | 10:09 PM
Formula350's Avatar
Dude, you have TWO threads going. Read one and you'll know what to do, sheesh.
Old May 9, 2007 | 06:33 PM
dhdenney's Avatar
There's nothing to plug if you have non emissions headers! You put the headers on, throw the AIR pump away and you're done!
Old May 9, 2007 | 06:41 PM
infinitebird's Avatar
^ well you do have to plug the hole on the stock intake duct or cai.
Old May 9, 2007 | 07:01 PM
z28hustle's Avatar
what have you guys used to plug the hole?
Old May 9, 2007 | 07:21 PM
I used a 3/4 vacuum cap from advance auto.
Old May 9, 2007 | 08:31 PM
the_merv's Avatar
Veteran: Air Force
Block the EGR in the back of the Intake, cut off the Cross-over Tube for the Air System, and cap off the little hole on the Intake. If you want to get rid of the EGR, you have to cap off the little spot on the Intake where it used to conect to.
Old May 9, 2007 | 09:10 PM
dhdenney's Avatar
Oh yeah forgot about that thing. I have SLP Ultra Z ram air and I used a bolt into the hole since it had a grommet in it.
Old May 10, 2007 | 02:58 PM
GrnZ's Avatar
haha im a fcukin idiot im sorry guys just took out the air pump i see what you guys were sayin srry. another question is what did you guys do as far as the studs sticking out of the block that held the air pump in place ?
Old May 10, 2007 | 03:08 PM
Fire67's Avatar
Air pump studs are on an aluminum bracket, unbolt the whole bracket from the motor.
Dont forget to Completely remove and block off the EGR stuff. Back of the manifold, two parts, a valve and a tube. Remove and install block off plates.
Another trick with those headers is to join the #1 primary (its two pieces) with some high temp copper exhaust rtv and a t-bolt clamp. If not it will eventually leak.
Old May 11, 2007 | 08:16 AM
GrnZ's Avatar
Can i leave the egr on for rite now with the AIR being gone ? will it hurt anything ?because i want to start installing them tonite and i dont have the block off plates for the egr yet ....
Old May 11, 2007 | 08:30 AM
GrnZ's Avatar
Also im goin to be splicing and soldering wires for the o2 extensions ,but what kind of wire did you guys use and where can i find some? Also how many wiresdo i have to splice from each o2 ? thanks guys sorry for being a newb to LT installation
Old May 11, 2007 | 09:32 AM
dhdenney's Avatar
Won't make a bit of difference. Might get a SES light though.
Old May 11, 2007 | 09:35 AM
dhdenney's Avatar
I had a serious time trying to solder O2 wires. I'm not much help there but know you might have some trouble. I could not get the solder to stick. I forgot which kind I was using though. You're going to have 4 wires on each sensor.
