96 vett scanner
Old May 7, 2007 | 12:36 PM
1BAD01TA's Avatar
Default 96 vett scanner
my car will not comunicate with a scanner, any ideas
Old May 7, 2007 | 12:41 PM
97LT1's Avatar
cig lighter fuse is run on the same. Baffled me for a long time until I asked.
Old May 7, 2007 | 01:28 PM
1BAD01TA's Avatar
checked it its ok still not scanning
Old May 7, 2007 | 07:06 PM
97LT1's Avatar
what type scanner? Have you checked your port and checked voltage at the power wire?
Have you checked the data wire that supplies info the scanner?
Are you getting anything from the scanner? (power up)
By Brett Foote | 2026-06-04 05:00:17
