lt1 question..
Old May 8, 2007 | 07:53 PM
Sunset'01Z's Avatar
Default lt1 question..
what does it take to get a carburetor on an lt1 engine?
Old May 8, 2007 | 08:57 PM
396D1SS's Avatar
a new intake, carb you can use the opti still or block the opti hole off and run a normal distrib on the back of the intake which will be easier
do a search there is tons of info on this
Old May 8, 2007 | 09:35 PM
Sunset'01Z's Avatar
who makes an intake though? i've seen one for lsx but not for lt1's.. unless a standard sbc manifold will bolt up which i doubt because of the rfc. the heads are different, i dont see why intake manifolds wouldnt be.
Old May 8, 2007 | 09:40 PM
396D1SS's Avatar
http://store.summitracing.com/partde...2&autoview=sku
the_merv's Avatar
Veteran: Air Force
Old May 8, 2007 | 09:41 PM
396D1SS's Avatar
Brand: GM Performance Parts
Product Line: GM Performance Parts Carbureted LT1 Intake Manifolds
Part Type: Intake Manifolds, Carbureted
Engine Block Style: Stock/OEM standard deck
Carburetor Quantity: Single
Intake Style: Dual plane
Basic Operating RPM Range: 1,500-6,500
Intake Finish: Natural
Intake Material: Aluminum
EGR: No
Quantity: Sold individually.
Notes: LT1 intake. Will not fit 1996 and later Vortec truck engines. The casting number on this manifold is 24502574, this is not the part number.
Intake Manifold, LT1, Dual Plane, Aluminum, Natural, Square/Spread Bore, Chevy, Small Block, Each
Check to make sure this part fits your application
Performance without the computer.
Dual plane GM Performance Parts' Carbureted LT1 intake manifolds make it possible to take advantage of the advancements found in Generation 2 Chevy engines. They allow you to install a carburetor on your LT1 engine without the hassle of running a computer or emission controls. They accept both Holley and Quadrajet carburetors, and feature longer runners that increase engine torque by up to 30 ft.-lbs. without sacrificing top-end power.
the_merv's Avatar
Veteran: Air Force
^^ We did that at the same time..
Old May 8, 2007 | 09:43 PM
396D1SS's Avatar
Old May 8, 2007 | 10:04 PM
Sunset'01Z's Avatar
jegs didnt have anything like that, i didnt check summit lol. thanks for the info!
