Retarded question time
Old May 11, 2007 | 09:18 PM
themadspoon's Avatar
Default Retarded question time
When installing the timing chain. Put cyl 1 at tdc with the timing mark at 12 oclock then the cam at 6 right?
Old May 12, 2007 | 05:51 AM
come on i know someone has an answer to this
Old May 12, 2007 | 06:55 AM
dhdenney's Avatar
Line up the dots. I did that in my cam swap and no problems.
Old May 12, 2007 | 08:19 AM
Formula350's Avatar
It won't install any other way I don't think.
Old May 12, 2007 | 10:55 AM
Captainofiron's Avatar
Yea its just like a SBC, line up the timing marks on the cam sprocket and the crank sprocket, its pretty simple
Old May 12, 2007 | 12:25 PM
Right cam gear at 6 oclock crank 12 oclock?
Old May 12, 2007 | 01:37 PM
yep, that would be correct, that installs the cam straight up, now if you want to index it at a different degree then its a different story
Old May 12, 2007 | 02:55 PM
dhdenney's Avatar
Most of us already have 4* ground in so I wouldn't see much need to install it any other way. But for those few that wanna be different, better use a degree wheel.
Old May 14, 2007 | 02:27 PM
thanks all
