guy please help
Old May 12, 2007 | 03:54 AM
Rickys S/C Z28's Avatar
Default guy please help
im in iraq right know and will be comming home soon. i need to order an ALT relocaion bracket for my wifes 93z be for i get home do yall know of any placs to get one??? and will i have to move the A/C??? thanks guys
ricky
Old May 12, 2007 | 05:57 AM
koolaid_kid's Avatar
It might help to know why these things need to move. Putting on a supercharger? If so, which one?
Old May 12, 2007 | 07:29 AM
i just hate the way it looks setting up there! and because the one thats on it right now is broke i figer id kill two birds with one stone.
Old May 12, 2007 | 08:16 AM
Formula350's Avatar
Well there's only 2 places it can go, left or right side. Looking at the motor, the left side houses the A/C compressor and the left side is where the AIR Pump chills. You CAN move the AIR pump somewhere else as long as you don't kink any hoses. Now, I don't know if they make a Alt Reloc bracket for that side, so if not then yes, you would have to remove the A/C.
Old May 12, 2007 | 09:18 AM
camar0corey's Avatar
A little bit of a thread jack here, so if I were to get rid of the AIR pump, I can move the alternator to where that was???
Old May 12, 2007 | 11:34 AM
PunishedU's Avatar
As far as i have seen, you could place the alternator where the air pump is, but I think the problem comes when you try to route a belt. I don't think there is a way to route the belt to make the set up work. I could be wrong, but it would definately have to be a custom job.
Old May 14, 2007 | 10:58 PM
ok man thanks for the help
