Won't start...?
Old Apr 28, 2003 | 08:24 PM
houseofboost's Avatar
Default Won't start...?
Something is messed up with my car. I was driving down the road and I let out of the clutch and it died. Rolled into a parking lot and whirled it over, wouldn't start. Got fuel, but no fire.
It whirls over and fires once and then just dead...nothing.
Any thoughts?
Later,
Wes
Old Apr 28, 2003 | 08:54 PM
96SCTA's Avatar
Default Re: Won't start...?
ok , have you checked to see if you have spark yet?? pull a wire(one from each side of the car) and have someone crank the motor over and see if you are getting any spark(put a spark plug in the boot and hold it to the block). if you are not then pull your coil wire . and check at the coil(multi meter). If you are getting a reading from the coil out put(wire that runs to the opti) then your opti spark is most likly dead. If you are not getting anything from your coil then your problem is either your coil or ingnition modual. Let us know what you find or if you have any other problems.
micah
