Quick temp question
Old May 24, 2007 | 11:33 PM
LT1Drew's Avatar
Default Quick temp question
My car runs about 220-230 degrees what is the normal temp for a 94 formula? It seems kinda high to run at 220-230 degrees dont you guys think?
Old May 24, 2007 | 11:38 PM
95greenZ's Avatar
Is it that high while cruising or sitting in traffic? The fans are setup to kick on around them temps from the factory. Get a tune, or fan switch to kick the fans on earlier.
Old May 24, 2007 | 11:42 PM
LT1Drew's Avatar
well in town its like 220-230 and while cruising its like 210-220 it just depends. But my predicament is when it gets in the 210ish area my car sputters and loses power. I wonder if there is a way ot lower your engine temp. I've heard 160 thermostat and royal purple ice but thats an iffy.
Old May 25, 2007 | 01:21 AM
95FbFormula's Avatar
MY CAR RAN THAT HOT TILL I PUT IN A 160 thermo. and also a new air dam for under the car helped also take off the rad cover and take a look might be dirty or something.
Old May 25, 2007 | 01:25 AM
Formula350's Avatar
That's avg temp.
