!EGR ! AIR??? help..
Old May 26, 2007 | 12:29 AM
383_LT1_1295's Avatar
Default !EGR ! AIR??? help..
okay guys...i finally got around to buying some longtubes...non emissions...what all do i need to delete the egr and air??
Old May 26, 2007 | 12:42 AM
F8L LT1 Z28's Avatar
both the pipe and EGR valve ports can be blocked off with plates. GM p/n 10054880 (known as the LT4 block-off plate) can be used to block off the ports where the EGR valve is removed
I got this info from here
http://shbox.com/1/4th_gen_tech1.html
Old May 26, 2007 | 12:43 AM
solarofthesix's Avatar
EGR Block off plates. 2 go on the back of the intake manifold. As for the Air, if you are going to non-emission headers all you need to do is remove excessive weight!
Old May 26, 2007 | 01:03 AM
okay..my question now..is where and how much can i get the block off plates for?
Old May 26, 2007 | 01:12 AM
the_merv's Avatar
Veteran: Air Force
I made my own.. I had the Intake off of it, so it was kinda easier..
Old May 26, 2007 | 01:19 AM
is it necessary to take the intake off?? cause if it is i might just wait until i do my H/C swap...
Old May 26, 2007 | 01:22 AM
H/C Swap?
as for it being necisary to remove the intake...no its not.....i would hit ebay and do a search for lt1 and goto the emissions section. I got mine for about 13$ shipped
Old May 26, 2007 | 01:25 AM
head and cam swap
Old May 26, 2007 | 01:34 AM
the_merv's Avatar
Veteran: Air Force
Ebay it up..
I had a set around here somewhere that disappeared
That is why I made my own.
Old May 26, 2007 | 01:46 AM
yea tehy are pretty easy to make as it was said when it is of the car its a load easier. I jsut figured if i paid 5$ for a sheet of metal from Lowes and then I would have to measure and cut it and all taht junk....instead i jsut spend the extra few bucks to have a quality peice sent to me.
DONT FORGET TO PUT GASKET SEALANT ON IT. Ive read some people forgetting this and then comming up with issues later on
Old May 26, 2007 | 11:58 AM
well they are all over ebay...15 bucks..not too bad i guess...
Old May 26, 2007 | 01:08 PM
yea it eliminates frustration. because i know i woulda thrown a few air tools across the neighborhood trying to fab my own
Old May 26, 2007 | 02:10 PM
Formula350's Avatar
Do you have to remove the EGR from the intake if you eliminate it from the exhaust manifolds?
I removed the AIR pump today and blocked off the drv side EGR. I didn't remove it from the head, just corked it. I need to get the brass fittings that were mentioned to really do it right. Anyone have the thread size for those again? :\
EDIT: Drove it once after I did the above, it seems to idle MUCH better now.
