quick question
Old May 26, 2007 | 05:48 PM
SchwabZ28's Avatar
Default quick question
I started putting my headers on my 1997 z-28 today and when i was disconnecting the o2's it looks at tho i have 3 of them. Can some1 tell me what is up? I can only reinstall 2 of them with my new set-up. i had 2 sensors before the cats and then one kinda right after the last cat. Any info would be great thanks
Old May 26, 2007 | 06:15 PM
Formula350's Avatar
97 should have 3. 2 per bank and one after the cat. You can get an O2 simulator for the post-cat one if you ever want to remove the Cat. Then it won't throw bad numbers.
Old May 26, 2007 | 08:24 PM
obe1 95Z28's Avatar
You should have 4 O2 sensors. There will be one after each of the 2 cats; the driver's side cat is located up close to the driver's side exhaust manifold.
Old May 26, 2007 | 09:40 PM
Formula350's Avatar
Oh that's right, twin cat on those ones Whhoops.
