valves help..... please!!!!
Ferrea 200/1.56..... i was wondering where i could get these vavles or what you guys have to say about them...?
The LE3 heads have 2.05/1.6 valves, so if your heads are fully ported, Lloyd seems to believe that they will utilize the larger valves. AI doesn't go any higher than 2.00/1.56 valves, unless their site has a typo. I'm guessing that it depends on the setup.
Seeing as you are only going to the 847, then I can't see why you'd need larger valves.
Good Luck,
Daren
