LT1 might be LTjunk
Opti was replaced with a MSD, 515.00 was a better price to pay than 674.00 that GM wanted for their P.O.S.
ouch! summit sells the for 3 something i believe. also try the gm parts sponsors on this board, they do wonders on getting u a part cheaper than your local gm dealer.
that is the sensor for the gauge located in the head there is a seperate sensor for the pcm located in the waterpump housing and it could very well cause the problems he is describing.
I don't see how it could be the ECM. Hardware is a work, or no work sort of thing. The software in them can't have problems like out computers, because they're built into a EPROM, not a hard drive. If it was in Limp Mode, he wouldn't be able to go like he is.
It could be the fuel pressure, but again, that can easily be attributed to the fuel filter not letting enough fuel pressure though.
As for the location, Billy is right. For the problem, this is my semi uneducated opinion: I don't think it would be causing that sort of problem. Seems more like it would still work normal, but would have less power throughout the RPMs, but he could still floor it and it not cut out.
Litch, the MSD Opti is only $519. Or was this years and years ago when it was new?
This is a bit far off, but could the Air Temp Sensor be bad, unplugged? I don't know how the cars react with it bad or unplugged, so it's a total guess.
Setting:
Last time car was ran was on 6/2 (just around the block)
Car has been sitting ever since on flat level driveway. 4 days
1: open gas tank cap to relieve pressure(Heard some hissing of air being relieved)
2: push in Schrader valve with Screw driver and Gas shot out!(Great no leaky injector???)
3: connect gauge
4: key on! PSI raised up to 10psi
5: let it sit for about 5 min
Still 10psi
6: start up psi raised to 19psi
Mybook says it should be between 41-47 at key on and drop about 10psi when running.7. Shut off Psi still at 19 and dropped while off to 10psi again.
8. Leaving gauge on over night just incase if drops any more.
also I really cant hear my pump when key it turned on..
IS IT MY Pump?? I still need to change fuel filter Should I do that first then retest??
I want to Drive again
So, again, I tell you, as I did in the FIRST REPLY, replace the fuel filter lol. I even said before you tested the PSI, a clogged filter will cause your PSI to not read right.
First we replaced the fuel filter. Didn't fix anything. Then we checked the fuel pressure. It was fine.
Finally we took it to a mechanic and it turned out to be a clogged CAT. Took it to the dealer and they replaced it for free. At the time (last summer) her car only had about 60K miles on it too.
i had to drive home at 4500 rpm cause the little sensors on it were dirty on time cleaned them and shazamm
