Highest spinning LT1
I´m at 6800rpm now on street motor with the opti and ECM
The ECM stops at 7250,can it be reprogrammed to spin higher?Where is the limit?
Ed's has a new 350 that he built that uses the opti and FAST system, it spins 8800 At the IHRA National this past weekend the rotor flew apart on him. This was a stock piece since then it was replaced with a stock piece and he pop rivet the rotor to keep it from flying apart. This has happened to me once so far on the stock piece.
The 350 made just a tad over 447 through a 6000 converter A3 TH350, stock TB, stock Heads, Stock Compression. He is running SS/JA class.
This is the one hard limit of this engine management system, no amount of reprogramming fixes it.
'87/'92 TBI pickup trucks only have 3600 rpm tables,and go well past 5000. Only thing the tables ending at a given RPM is that you can't make tuning changes after that RPM. '96/'2000 Vortec trucks have 6000 RPM spark tables and 6400 RPM P.E. fuel tables, but won't rev past 5400/5500. It's not the RPM where the tables stop. Wish it were that simple.
Ed, I want that"special" ecm
David
David
I got dibs
OH YEAH! IF my wifes cars was any thing but an LT1 would I be posting about it?
