Jasper Performance Products
1992-1997 LT1 Chevrolet
Class II Version - Chevrolet 5.7
Version Description:
The Class II Performance engine is for the serious performance minded person who needs power for a
specific application. These engines are built with heavy duty performance in mind. Special components
and procedures are selected and matched to obtain maximum performance for your application.
Not intended for use on pollution-controlled
motor vehicles.
340 hp (estimated) @ 5000 rpm 383 ft. lbs. Torque (estimated) @ 4000 rpm
Version Applications:
Performance oriented cars and trucks
Street Rods and restored muscle cars
Small/medium size engines requiring
good low speed torque
O.E.M. replacement
Part Specifications:
Approximate 9.75:1 compression ratio
High performance rod bolts and nuts
High rev lifters and performance valve
springs with retainers
High volume oil pump
Cloyes timing set
Flat top hypereutectic pistons and moly rings
Harmonic balancer
Screw in rocker studs
High performance stainless steel valves:
1.94 Intake; 1.5 Exhaust
Class II camshaft
High performance bearings
High performance head gaskets
Machining Specifications:
Kolene Salt Bath cleaning
Three angle valve seat machining
Precise surface finish measuring
Square decking of block
Main saddle align honing
Electronically balanced engine assembly
Torque plate honing
Computerized boring
Precision crankshaft machining, oil hole
chamfering and polishing
Live testing
If it is to be used only for daily transportation in stock form, it may be ok. If you're looking for a hi-po engine find a good performance shop to build it for you.
