Car dies
Old Jun 3, 2007 | 09:48 PM
MysticLT's Avatar
Default Car dies
I have a 97 SS camaro. Ok for the last two days my car has done well for 30 min but after that it dies. It will start to sputter then just die. I put my car in park after i got it started, and reved the engine up to 4K and it sputtered after it got there to 3 K and then just died. I had not moved my foot on the pedel it just lost something. And my temp was at the 3/4 mark on the gauge. It brings up codes for my egr being taken off and a code 1371 engine missfire or ignition system. My fuel pump does turn on and pressurise the system. Any ideas what is going on.
Old Jun 3, 2007 | 09:54 PM
infinitebird's Avatar
I'm going to guess the opti is going out. High rpm sputtering and cutting out are typical symptoms of that. I would check the coil and plugs/wires first though, as they are much cheaper to fix.
Old Jun 3, 2007 | 09:56 PM
LT1's Avatar
LT1
it has to be the opti spark! excatly what your discribing. i just did one for a friend same excat problem.
Old Jun 3, 2007 | 10:06 PM
the_merv's Avatar
That good ole OPTI for ya..
Old Jun 3, 2007 | 10:09 PM
LT1's Avatar
LT1
no kidding, thats the only thing that i hate about our LT1, opti crap!
Old Jun 3, 2007 | 10:17 PM
MysticLT's Avatar
Well i had just replaced the opti 1000 miles ago, and i do have a small leak somewhere but i don't believe that it has gotten wet yet. It may be possible. Would the opti go out only when it warms up. because it is fine untill like 30 min later. it acted different when it went out before. it was crap 24/7.
Old Jun 3, 2007 | 10:22 PM
LT1's Avatar
LT1
maybe a bad coil?
Old Jun 3, 2007 | 10:28 PM
the_merv's Avatar
Yea, that could be it too...something in the Ignition System.
I couldn't see the OPTI goin out when it warms up, that would be kinda contradicting itself being located on the front of the Block..
Old Jun 3, 2007 | 10:53 PM
MysticLT's Avatar
I also just replaced the igntion coil about three weeks ago.
Old Jun 3, 2007 | 11:10 PM
SuperDave383's Avatar
sounds like it has to be something in the ignition system.
Old Jun 3, 2007 | 11:13 PM
MysticLT's Avatar
would it be best to take it to a shop and hook it up to a computer and see what they come up with. Becuase i don't know what else to replace.
Old Jun 3, 2007 | 11:47 PM
LT1Drew's Avatar
Acually my opti would only act up after the car heated up...after i replaced the stock one with a MSD all the problems i was having just stopped. I was running 9.4 in the eighth and now im running 8.9...weird huh.
Old Jun 4, 2007 | 04:25 AM
Blackj98's Avatar
i know how to fix it for you bro...put a for sale sign in the window
Old Jun 4, 2007 | 11:12 AM
If it only acts up when warm it could be o2 sensors.
Old Jun 4, 2007 | 11:53 AM
Ls1Bait's Avatar
Is that how you fix problems?
About the ignition problems put a spark checker on it (you can get one at any automotive store like Harbor freight) Put it on each wire while its running to see if they all get spark.
Second try to test fuel pressure, and maybe a fuel filter. If all else fails throw some new parts at it to see if it fixes it...lol
