O2 help please!!
Old Jun 4, 2007 | 12:33 AM
goodrich969's Avatar
Default O2 help please!!
I need some help. I may sound dumb but, I need some help installing O2's. I know you screw them in and wrap them in heat wrap, but I have no idea were to plug the o2 extension into. If someone can point it out and where its located, or some pictures or a link to some direction, that be awesome. Thanks
David
Old Jun 4, 2007 | 04:33 AM
Formula350's Avatar
When you unplug the O2 on the car, you plug the extension into each side. The side that comes off the O2, and the side the O2 plugged into.
So if this is how it is when you go under the car:
=====[X]----[o2 sensor]OO
Then you unplug it
=====[X.......]----[o2 sensor]OO
And then insert your extension
=====[X]==========[X]----[o2 sensor]OO
Old Jun 4, 2007 | 06:20 AM
z28hustle's Avatar
im sure that was amazingly un helpful like you when it comes to my th350 .. you need to contact me mr. goodrich..
Old Jun 4, 2007 | 09:29 AM
Can someone please simplify that?
Old Jun 4, 2007 | 11:07 AM
mattraypharbor's Avatar
its easy a trained monkey could figure it out.
Old Jun 4, 2007 | 12:55 PM
Ughh, thanks for the help I hate people.
A simple answer would of helped but you had to go straight to being a dick.
Old Jun 4, 2007 | 01:06 PM
Ralls's Avatar
The o2 is threaded into the header. At the end of the o2 there is a connector. You unplug it and plug in the o2 extension from there so you have an... extension. Thread in the o2 sensor WITH ANTI SEIZE without plugging it in first so the wires can freely rotate and not bind up. Then plug in your o2 sensor and walla
Old Jun 4, 2007 | 03:35 PM
Formula350's Avatar
What extension are you talking about? The wired extension or something else? If you can't figure out the wired extension, I really don't know what to tell you lol As said above, a monkey could figure it out, and I don't mean in years and years, but in about 5 minutes. And do what Ralls said with the Anti Seize, or you'll be pissed at yourself when you have to replace them next time and can't get them out.
BTW Hustle, it's Mr Goodwrench
Old Jun 4, 2007 | 05:42 PM
No I have casper extensions. I just dont see where the end of the o2 plug into after I thread it into the header.
Old Jun 4, 2007 | 07:03 PM
I found the passenger 02 but I still cannot find the drive side. I know its by the master cylinder but I dont know.
Old Jun 4, 2007 | 08:27 PM
Ralls's Avatar
You have stock manifolds?? Not long tubes? I figured with heads and cam you would be past stock exhaust manifolds by now? I don't know if that's true but that's what I'm getting from you. And on top of that if it is true, why are you getting extensions? Fill me in please!
Old Jun 4, 2007 | 10:33 PM
I have LTs. I was told I needed extensions. When I got the passenger o2 on I needed the extension. I just need to find the driver side.
Old Jun 5, 2007 | 05:52 AM
Ralls's Avatar
If you have longtubes, then how can you not find both o2 sensor's? They are directly opposite of eachother. Plain as day. One on each header at the same spot.
Old Jun 5, 2007 | 09:55 AM
ughh, I know where they hook up to on the header. I need to know where they connect to after that.
Old Jun 5, 2007 | 12:11 PM
SlowGreenTA's Avatar
The driver side O2 plug is behind a small heat shield just off the back of the driver side head, right up against the firewall.
-Josh
Old Jun 5, 2007 | 12:14 PM
Thank you, that helped definatly. I swear the guy who helped me tucked it away somewhere because I hunted forever and I could not find it.
Old Jun 5, 2007 | 12:29 PM
Josh- That ******* helped very much, found it in about 10 seconds. Thanks alot man.
Old Jun 5, 2007 | 12:32 PM
np.
-Josh
