Help Help Help!!!
PLEASE HELP!!!!!
Now, explanation aside, the not going over 20 and sputtering REALLY bad, sounds like Limp Mode. As for the temp jumping around, that runs off a different sensor I think even for your car. If the gauge runs through the ECM, then that's even more to the theory of it going out. I would check and see if you can remove your chip from your ECM. I assume that, even with your style PROM being reflashable inside the ECM, it's still removable. Doing that will make it go into Limp mode. Compare how it acts then, to how it acts when it can't go over 20.
Sorry I can't be of much help.
