93-97 V6 replacing radiator
Old Jun 5, 2007 | 08:16 AM
105's Avatar
105
Default 93-97 V6 replacing radiator
My friend has a 93-97 v6 camaro and he wants to replace his radiator. Is this something that can be done pretty easily? I've done a few things to my 01 Z but I have no experience when it comes to a 93-97 v6. Any advice/instructions would be greatly appreciated.
Old Jun 5, 2007 | 11:00 AM
Torkman15's Avatar
10 Second Moderator
Earlier cars arent much different than your 2001 in this area. Very easy job, just drain the coolant (I use a clear hose about 4 ft long and siphon from the fill hole) Take the 3 bolts out of the top support, take hoses off and the trans cooler lines if its an auto, unplug the fan wire (the fan is attached to the rad with a tab in slot setup so it will come out with the rad or you can pull up and take it out seperate) A/C condenser is tab in slot too, pull up on it and make sure all four points come apart then pull the rad up out and put new rad in reversing everything. Good luck to ya, Tom
Old Jun 5, 2007 | 11:16 AM
105's Avatar
105
Thanks, I'll give it a try.
