Is this the opti?
Old Jun 5, 2007 | 09:05 PM
NXSLT1's Avatar
Default Is this the opti?
Just put the blower and everything back on it and took it for a drive to see how the meth injection was gonna do and see if I cured the knock problem and was loading the engine pretty good when it backfired a couple times then would barely run. It would give me no more than 5 degrees timing no matter what. I got no codes either. Sound like the opti or ICM or what?
Old Jun 5, 2007 | 09:41 PM
MEAN LT1's Avatar
Sounds like you need to data log and see what shes doing.
Old Jun 6, 2007 | 04:47 PM
NXSLT1's Avatar
The only thing odd showing up is the 5* timing issue. It was misfiring bad and trying to pull out fuel because of it, other than that everything was normal.
Old Jun 6, 2007 | 05:50 PM
Zralou's Avatar
PCM gone bad?
Sara Lou
