what is the best engine setup N/A
Old Jun 6, 2007 | 11:35 AM
transam1577's Avatar
Default what is the best engine setup N/A
if you were going to build an lt1 for the most power you can get while keeping it naturally aspirated and a dailly driver (reliable) how would you build it? because i am trying to get the best ideas to build my motor right the first time.what do you got?
Old Jun 6, 2007 | 11:55 AM
sworaz's Avatar
Probably heads and mild cam
or
Spray power when you want it
Old Jun 6, 2007 | 01:58 PM
LT1_King's Avatar
yeah a good H/C package and a 100 shot would be good. you can't go wrong with a Lloyd Elliot H/C package.
Old Jun 6, 2007 | 04:19 PM
FASTFATBOY's Avatar
N/A means NORMALLY ASPIRATED...at least where I come from..AKA no power adder.
Here is what you need.
383
AI 200CC or LE3 package with a hydraulic roller
12to1 compression, 8.7to1 dynamic compression.
Hooker longtubes
4 inch Mufflex
roller rockers
ported intake
58mm throttle body
42lb injectors
K&N cai
All associated/supporting mods, including a dyno tune.
David
