Thinking of going 383. Is a stall change necessary?
Old Jun 6, 2007 | 03:30 PM
big dave's Avatar
Default Thinking of going 383. Is a stall change necessary?
I'm considering the 383 because of the increased low end torque and not having to rev the motor high to achieve decent power. My 3200 stall works perfectly with my current combo but would it be too much for a 383 with no other changes being made to the heads and cam?
Old Jun 6, 2007 | 07:07 PM
titter's Avatar
No. That will actually be pretty good ... and would really like spray.
Old Jun 6, 2007 | 08:15 PM
ABA383's Avatar
I run a Vig 3600 in my combo and it may need a bit more...Vig told me once that for optimal street/strip performance you want your converter to stall 500-900 rpm below the torque peak of the motor...I forget the specs of your cam and where you make your peak torque, but the 3200 should be a good starting point...
--Alan
