Crank bobweight
Old Jun 11, 2007 | 12:20 PM
Ari G's Avatar
Default Crank bobweight
What is the Bobweight of the lt1 crank?
How much of a driffrence is "safe" to spin to 7000rpm,what is the +\- offset on it?
Isinīt there a error in the bobweight on the crank for the piston-rod assembly weight because of the aluminium light weight pistons?
Old Jun 11, 2007 | 04:24 PM
lethal93ta's Avatar
bobweights very from engine to engine, not every rod and piston weight the same, if you want to spin 7000 RPM you better have everything to with in +/- 1/2 gram if you want it to stay together.when we spun my assembly up we balanced it to with in 1/4 of a gram. the right way to balance is to balance the pistons, I have SRP pistons in mine and they were about 2 grams each off, we flycut under the piston to get them to with in a 1/4 gram, then you weight the big and small ends of the rods and make all those the same, all my manley rods were dead on, then you have a formula you add the piston and rod weights together + you add some for the oil weight, you even need to know your bearing clearance and how much oil will be in there, it take a lot of time to balance one right.
Old Jun 11, 2007 | 07:11 PM
Ari G's Avatar
I know how to match and such but what is the LT1 crank stock bobweight?
Iīm spinning my stock bottom end to 7000rpm with no problems
I have read that the bobweight for the stock crank is a bit off,is that true and how much is it?
Old Jun 11, 2007 | 08:42 PM
DroppedM6Z's Avatar
you sig has me confused.....are you spraying a 400 shot?...I feel stupid asking that but really?
Old Jun 12, 2007 | 11:25 AM
Ari G's Avatar
No,I have a direct system that i still havent used and the 400 is the max on the system(solenoids)
