need help asap
Old Jun 11, 2007 | 06:36 PM
1996Formula's Avatar
Default need help asap
when i push in my clutch and go to put it in gear its a lil hard to get into gear, and the car makes a screaching noise (not too loud but loud enough to hear with the car running. if i pull it back out of gear with the clutch in it gratually stops. if i take it out of gear and let the clutch out, it instantly stops. please tell me whats wrong. im trippin out over it, and hoping its not to expensive of a fix. it started when i left a gas station. i rolled into it a little bit in 1st, then it was a little hard to get into gears. not too hard, but definately had to give it a little pressure.
Old Jun 11, 2007 | 09:13 PM
seawolf06's Avatar
You probably just need a new clutch. If you drive it like that it might mess up your tranny, too. Could also be a couple other things, but a bad clutch is most likely.
