Balancer hub removal?
Old Jun 12, 2007 | 09:31 PM
I8ASaleen's Avatar
Default Balancer hub removal?
So I need to take off the balancer hub to take the front cover off b/c it has a horrible leak and I'm replacing the opti, E-WP, and timing chain. I tried a balancer puller with my 1/2" air ratchet set on full force and the thing would not budge!!!??? I put some PB Blaster on it and am gonna let it sit for a few days, but man that thing is ON THERE. Any helpful hints?
Old Jun 12, 2007 | 09:40 PM
Irish350's Avatar
lol... it is officialy impossible. youre gonna need to just lower the front of the pan a little bit and pull the cover forward, and let it hang
Old Jun 12, 2007 | 10:31 PM
Blackbirdws6's Avatar
your most likely actually pulling on the hub itself. I had this issue myself when taking the hub off. Put a 1/4" socket extension in the hole, use the puller again and you should get it off. good luck.
-Brian
Old Jun 12, 2007 | 10:59 PM
Paul Bell's Avatar
That's MISTER MODERATOR
https://ls1tech.com/forums/showpost....01&postcount=5
Old Jul 17, 2007 | 03:45 AM
Irish350's Avatar
i take it back. i actually pulled mine today. i was ******* dismayed.
