Thinking of buying a high mileage LT1
Old Jun 15, 2007 | 06:00 PM
LT Malice's Avatar
Default Thinking of buying a high mileage LT1
I found a dirt cheap 97 camaro with 134K that I'm thinking about getting. I have a reliable daily driver, so I just want a tinker toy to play with until I get my new 09 camaro in a couple years.
What are some things I should look out for when buying a hi mileage car? I know that optispark can be a pain sometimes, but summit has cheap replacement units. It seems to me that head gaskets blow on LT1 cars with hi miles pretty often. What other stuff should I look out for?
If I get it, I might put new head gaskets in it just for cheap insurance. After that, I'll prolly just install headers and have fun until it blows up or I sell it.
Old Jun 15, 2007 | 06:23 PM
Cole Train's Avatar
yeah they are pretty reliable in themselves. They can have little things go out and can be frustrating but if you don't mind tinkering, they are good cars. I like to work on mine. I get frustrated with stupid stuff but in the end it's ok with me as i LOVE my car The opti isn't that hard. i've done it twice in 2 months because i went cheap the first time. Got a new GM unit and been good. I've read or the headgaskets but they aren't all that hard to change i've heard.
Old Jun 15, 2007 | 06:25 PM
LT Malice's Avatar
I thought that all in all they were pretty sturdy. I do hate searching for electrical gremlins though.
Old Jun 15, 2007 | 06:29 PM
Cole Train's Avatar
mine had an arcing plug wire problem and the opti harness went bad and caused it to not start in the morning. put in Accell 300+ plug wires with Accell plug wire sleeves in and NO MORE arcing. The Opti harness should have been replaced when i put the first new opti in but i got dumb. Let the old stocker in. Then when the new opti case cracked i replaced with the GM one and then the starting problem. Changed out the harness for the opti and boom, started right up. The connector was all dirty and bent up. Runs great now
Old Jun 15, 2007 | 08:24 PM
Rowdy94's Avatar
A high-mileage LT1 is 200k+. 130-something is just barely broken in.
Really though, if it runs strong and drives fine, you shouldn't run into too many problems. I don't notice any more head gaskets going in LT1s than any other engine. That normally happens from overheating. Don't let it overheat, and you'll be fine. Higher mileage LT1s have a tendency to spin a bearing when hit with a cam/head combo. I'm not sure what you want to do to it, but if doing anything crazy, just rebuild it.
Old Jun 15, 2007 | 08:27 PM
razorclaw99's Avatar
haha that makes me feel comfortable about my lt1
Old Jun 15, 2007 | 11:51 PM
speedylexus2006's Avatar
My Bother Bought A 96 Camaro For 3k With 150k Miles Runs Hard And Just Put On Pacesetter Headers And A Entire Magnaflow Exhaust Sounds Good And He Put A $40 B&m Shift Kit By A Flip Of A Switch I Also Put That In My T/a Hits Hard And He Also Did A Intake Gasket When He Got The Car Since It Was Leakin Oil.also He Put In Msd Wires And Tune Up And Manual Electric Fan Switch He Made After Looking At Mine I Just Bought Brand New For $70.00. He Now Makes Them For People And Sells Them For $40.00 Pretty Cool
But Runs Mean And Sounds Mean.i'd Go For It
Old Jun 16, 2007 | 02:17 AM
Cole Train's Avatar
^ Holy run on and caps batman lol use sentences and less capitals there man. Sound like your so excited ya don't take a breath....
Old Jun 16, 2007 | 06:58 AM
96redcamaro's Avatar
I can say from personal experience that they can can take ALOT of abuse. mine says 17x,xxx on the clock. although i just had a new motor put in, but the old one was still running fine.
Old Jun 16, 2007 | 09:10 AM
meangreen94z's Avatar
Yeah mine has 182,xxx on it. original engine, trans, etc.
Old Jun 16, 2007 | 09:16 AM
thebufenator's Avatar
uh......question.....mine is at 120k, its a 93:
I noticed that sometimes the oil pressure fluctuates, while I am maintaining a constant rpm
what does this mean?
Old Jun 16, 2007 | 09:54 AM
1994t/a's Avatar
before i got my trans am i had a 95 z28 6speed that i bought with 180,000 on it.it had 206,000 on it and still ran awsome when i got rid of it.never used a drop of oil between changes or left me stranded on the road.i drove it once a week to B'ham from Huntsville,AL which is about 140 miles.It got about 28-30 mpg on the intersate.i was the second owner of the car,it was very well taken care of by the perivous owner and me too.
Old Jun 16, 2007 | 12:00 PM
UA-Plumber's Avatar
Mine just turned 130,000. I am the 2nd owner. Uses no oil, and runs good pressure. Runs a 14.1 with just a CAI and Muffler. They are pretty reliable motors if maintained properly.
Old Jun 16, 2007 | 11:27 PM
Turnin20s's Avatar
+1 take care of it and it will treat you well. Mine on the other hand.....The previous owner/s didn't take that good of care of it. The body is near perfect, tranny is great, but they didn't change the oil or do routine maitence (SP), but you can't really tell unless they have reciepts. I got the car bone stock and had it for a grand total of 90 miles before spinning the #1 rod bearing and breaking 3 rings, but I was driving it really hard. I'm not trying to make you second guess yourself, these cars are awesome I love mine even though it has fought me the whole way, but I know when I get the bugs worked out it will run hard.
Good luck
Old Jun 16, 2007 | 11:46 PM
infinitebird's Avatar
I just bought a 136k mile lt1 and it runs great so far. Like said, whether its been taken care of is generally more important than mileage.
Old Jun 16, 2007 | 11:56 PM
NovaTodd's Avatar
I bought mine with 223,000 miles. It ran great with the common problems (leaking intake, leaking pinoin seal,ect). I lost a water pump at about 224,000 (only driven here and there - not everyday) and ended up blowing both head gaskets and warped one of the heads. I don't blame the car or the person who sold it to me.
Several of the people who have posted above are 100% correct, if the car was maintained well, you will only have to tinker with it and deal with the normal issues.
Get the car - mod the hell out of it and enjoy it until it is time to get the new one.
Old Jun 19, 2007 | 11:59 PM
jay97z28conv's Avatar
I talked to my old boss a a junk yard he has worked at one for 25 years before I bought mine. he said the only pain in the *** was the opti spark.
