need help badly!
Old Jun 16, 2007 | 08:40 PM
1slot/a408's Avatar
Default need help badly!
i need to find a picture or diagram of where the rediator hoses go hooked up..i have a 95 T/A m6 and confused to where the hose from the bottom of throttle body goes to the radiator? can someone help please????
Old Jun 16, 2007 | 08:43 PM
Phantomhp's Avatar
Which port on the throttle body are you talking about?
If your talking about the port directly under the throttle body opening that faces towards the drivers side then it goes to a port on the passenger side of the radiator right above where the tranny line hooks up.
Or you could just do the throttle body bypass.
http://shbox.com/1/tb_bypass.jpg
Old Jun 16, 2007 | 11:33 PM
1slot/a408's Avatar
i think there is only one hose that goes from the throttle body(its under it) that goes to the radiator..i dont think its even to the throttle body..its on just under it to the radiator
