pacesetter header gaskets needed
Old Jun 20, 2007 | 01:03 PM
Taubr Unit's Avatar
Default pacesetter header gaskets needed
How many reused the copper header gaskets you got with your headers? They say since copper is a soft metal you can reuse them. But the pass. side header is the only one i took off and now i got a mystrious tick from that side. Im pretty sure its not the gasket but im gonna replace it so i can rule that out. Problem is i cant find copper ones or even reg. felpro with a big enough port and i dont wanna "port" the header gasket cause then there be no sealing there. Where do i get copper header gaskets with a big hole in it?
Old Jun 20, 2007 | 05:01 PM
Razor_Blade's Avatar
Fepro #1406. D port, 1.5" high and 1.6" wide. Any decent speed shop will have them.
Old Jun 20, 2007 | 10:41 PM
cruzin94's Avatar
dose any one use the old ones or is that a no-no
Old Jun 21, 2007 | 06:05 PM
Taubr Unit's Avatar
i did and now i think they leak but i wont know till i replace it.....
Old Jun 21, 2007 | 07:20 PM
indirocz28's Avatar
Just do what dragracers do- copper RTV sealant. - mine dont leak, and neither have any of the drag engines we've built..
